It is currently Mon Aug 18, 2025 11:16 am
 Post subject: Cam Clamps slipping?
PostPosted: Sun Jun 29, 2014 7:12 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
Got a coupla cam clamps that are slipping...they have worked quite well until this month....Basically, after tightening clamp, it loosens over a 60 second period....gotta fix or replace. Would rather fix.
-Wood is not cracked,
-no oils on the steel bar,
-cam bar is good
-back of steel is getting shiny....do I need to re-groove the back edge? Re-file grooves?
any ideas for fix? Thanks.
 Post subject: Re: Cam Clamps slipping?
PostPosted: Mon Jun 30, 2014 1:46 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
the most important thing to remember when using
cam clamps are to -position it-Bring the bottom & top pieces
to the joint-Then hold the bottom & top (wooden parts) tight at the back
just behind the steel bar -then adjust the cam .
Practice this with non -important pieces.
Mike Collins
PostPosted: Mon Jun 30, 2014 2:12 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
I don't have any cam clamps. But there is a thing on the internet that shows how to make your own. I would like to have some.
PostPosted: Wed Jul 02, 2014 12:58 am
First name: Enrico
City: Rome
Country: Italy
The same happened to me. I own about 15 cam clamps. Two of them showed the same problem you are having. It has nothing to do with how you clamp them. I am pretty sure they are broken. Either you try to fix them (you have to figure out how), or you throw them away. I still have them, but I don't use them anymore. It is too dangerous. I also wrote to klemsia but received no answer. Sorry I could not help.
PostPosted: Wed Jul 02, 2014 5:07 am
If the grooves have worn smooth you could try a re-file.
Are they Klemsia or another brand?
I have about 30 Klemsia clamps and haven't had any problem at all with them over the years.
PostPosted: Wed Jul 02, 2014 9:04 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
The cam relies on wood-to-wood friction. If those surfaces become contaminated, the cam can slip. I disassembled one of mine, a few swipes with 120 grit and a splash of naphtha. Reassembled, problem solved. YMMV
PostPosted: Wed Jul 02, 2014 2:08 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
Klemmsia clamps are still working.....these are a different 'brand'.....I'll try cleaning/roughing up back edge.....thanks.
Users browsing this forum: TimAllen and 5 guests
